Wow looks great! What brand tire? Are you only running a level kit? Any rubbing?
Mr. eXtreme
Jul 14, 2009 11:05 AM
Originally Posted by ab46501
(Post 3801999)
Thanks Guys! Tires are 325/60/20 Hankook Dynapro ATM RF10's new on the market and in a write up in Motortrend they beat out the BFG's!
Also they cost me half as much as the BFG in the same size. And 70 less a tire then the BFG's a 285 too!
VERY Quite, great in the rain, hauling a load.
Once the spacers go on going to try them off road.
I'm running 2.5 inch AS spacers up front and 3 inch AS blocks in the rear.
They are very close to the ball joints do to the larger side lugs but the 1/4 inch wheel spacers come today so that'll be fixed! At full lock right now they rub a little on the upper control arm and sway bar and a little on the frame but I'm hope full the spacers will take care of this too.
If not the plan is to install a 4 inch rancho next spring anyway.
Needed tires so went with what I would have if I already had the lift!
Only other thing I did was trim a little bit off the lower valance wear it rubbed while backing up. Well worth the little extra work imo!
Will keep you posted once I put the spacers on tonight.
That really is a good looking tire! Reminds me of the bridgestone duelers. I didn't think you could go that big on stock rims without a lift. Glad to know it will work! That size might be in my future. Let us know how the spacers work out?
mdhawkin
Jul 14, 2009 11:17 AM
Thats a good looking AT, what kind of performance hit did you take?
Mr. eXtreme
Jul 14, 2009 11:35 AM
Thanks will do! I'm getting around 14 mpg city with the larger tires.
