Are you running over size tires? What would u do if you had a flat?
Im running 325/60/18 tires and take my truck on vacation a lot out of state. Ive always wonder what I would do If I got a flat being the stock jack wont go high enough and dont have a spare 325/60/18 tire?
I do have triple A and could call them to raise the truck and I have a tire repair kit I could use. I wonder what it would be like it my tire ripped apart if I could use the stock one under the bed of the truck with my other (3)325/60/18s?
Im sure a lot of people have bigger tires then me too. So im just curious whats your game plan if your out of state and have flat and bigger tires then the ford stock ones?
Just carry a 33" tall spare. I carry a 35" with a small floor jack and a block of wood to gain extra height. If you have a limited slip rear end it's good to have the rear tires the same height, the front dosen't matter unless you engage the front wheels on a 4x4.
i run 325/60/20's on a rancho 4 in lift, blew a tire the other nite on the freeway, change the tire, put on the stock size tire, drove it straight home and parked it until discount tire could order me another one, took them two days, and i had road hazard but it only covered the cost of the maximum size oem tire, so i paid the difference plus a deductible, all said and done i got a new tire in two days, paid 98.47 for a kumho road venture AT 325/60/20....not a bad price at all. i just didnt drive truck because i didnt want the axle heights to pose a long term problem. oh, and with the stock jack, i just put it on the bottom arm of the shock.. not the greatest of moves, but it was 1045 at nite and in a bad area of town, not alot of options.
Just keep a tar plug kit with you...it happened to me one morning...picked up a nail the night before and came out the next morning to find it sitting on rim...plug it enough to slow the leak, and pump it up to around 60 psi..drive straight to the nearest shop(15 minutes for me) and got a tractor plug put in it! haha!
I've got 35x12.50x17 tires and have changed one twice using the stock jack and did so without any problems? I was kind of surprised that I was able to do it using the stock jack, but it did just fine and even on a dirt road too.
Thankfully it wasn't the rear tires that went or I would have had to do a double tire change to keep the diameter the same on the rear tires.
