Tires on 05 F150
How big of a tire can I go on my 2005 F150 supercrew? No lift kit in the front.
With no level in the front, you should be able to fit 33"s. If its 2wd, you may need to do some cutting.
Update. I added a 2" Ready Lift to the front. It looks great. Any idea on what tire size I can go up to now?
What size wheels are you running now and is your truck 4x4 or 4x2? If you have factory 18'' and 4x4 you can run 35x12.50 with a little rubbing at full lock, with 4x2 you can run a 33" x (11.50 - 12.50 range). If you are running another rim setup let us know.
Also, please use to learn the search feature, the question you are asking has been asked and answered many times over. By searching you will get the answers you are looking for quicker, along with pics etc....Welcome to the site. |
17" Wheels and it is a 4x4. Thanks for your help. I will try the search. I am still learning this site. Thanks again.
ive got 285s but you should beable to fit a 35" with minor rub
