So, I'm looking at these wheels...
and I'd like to purchase, but they give no info on offset or backspacing. They are ATX Artillery 18x9's.
I currently have stock 17's, no lift/level kit installed. Will these fit?
http://www.tirerack.com/wheels/Wheel...odel=Artillery
Also, the tires I'm looking at are 275/65-18...will these cause me any issues?
Thanks in advance for any assistance.
Am I good with these specs?
If the wheel specs for the 09's are the same as the 04-08's, those AR wheels will stick out about 2.5 inches farther than your oem wheels. They should work with the size you are looking at but personally I'd add a leveling kit and go with a larger tire like a 305/60-18 (33x12.50) or at the very least a 285/65-18 (33x11.50).
The wheels I posted were one of the suggestions from tirerack.com after I put in my vehicle info. I assume that means that evens 20's would fit okay since they were also suggested?
