F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Wheels, Tires & Brakes (https://www.f150online.com/forums/wheels-tires-brakes-29/)
-   -   325/60R18's (https://www.f150online.com/forums/wheels-tires-brakes/332083-325-60r18s.html)
kkelso May 5, 2008 09:55 PM
325/60R18's
...on a 2WD F150 SuperCab? Just wondering what you think because I ordered the Terra Grapplers with XD Monsters yesterday. I'm hoping they will fit! I am putting them on after the leveling kit is installed, and I know I'll probably have to cut some of my front fender. Do you guys think this will size will fit with some cutting??
GTRider245 May 6, 2008 08:55 AM
I would think not on a 2wd. They fit with a little room to spare on a 4wd.
wandell May 6, 2008 12:41 PM
I agree. I'd add a body lift also.
Hash278 May 6, 2008 01:02 PM
A body lift with the leveling kit should do the trick. What are the specs on the wheels you ordered?
Big50 May 6, 2008 04:12 PM
You will still rub the inner fender which you can't trim much b/c there is metal there. I don't know if your aware that 2wd are 2" lower than 4wd's. So, you are basically trying to stuff 35's into what is a stock level 4x4. Good luck, sounds like a sweet tire and wheel combo:thumbsup:
wandell May 6, 2008 04:21 PM
He's asking about 325/60-18's which are basically a 33x13.00 tire. The wheel will play a huge part in fitment. You should be fine with a leveling kit and body lift if you use a 9 inch wide wheel with 5 to 6 inches of backspacing.
kkelso May 6, 2008 07:32 PM
Why can't I just cut through the metal?
kkelso May 6, 2008 07:35 PM
Body lifts cost double the price as they cost to install them. They are a waste of money and if I was going to spend $900 getting a body lift installed, I might as well save a couple extra hundred bucks and get a real lift. For the F-150, the whole interior of the cab has to be taken out to install the body lift, as I hear. Also, the specs on the wheels I ordered are 18x9, Offset: -12, Backspacing: 4.53.
Hash278 May 6, 2008 08:36 PM
Well since you dont want to do a BL lets hope they fit with those wheel specs.
kkelso May 6, 2008 08:42 PM
Yeah I'm a little nervous about them fitting, but the place I'm going to I trust very much and they will do anything to get those tires to fit. I'm sure they'll have to cut a lot of the fender but its worth not having to send those big 325s back in the mail! :D
Big50 May 7, 2008 01:15 AM
You can. However, there is only so much you can trim and there are several body panels conecting in that area. There's a good chance it still won't fit.
