Will 35's fit??
I have a 2004 Fx4 (Bone Stock) and am fixing to install a 2.5 leveling kit, i was wondering if 35 inch tires will rub? i am keeping the stock wheels .. or should i go with the 34 inch tires? :confused:
Since your keeping the oem wheels you shouldn't have a problem.
ok thanks, cuz i've heard different posts about some rubbing, no rubbing, im not sure whats what
they rub at full lock (well thats with the nitto mg's huge thread pattern on the sides.
I definately rub at full wheel lock. There is also VERY little space between the upper control arm and the lugs on MT's. It's not something I worry about so I just learn to stay away from full wheel lock and am happy with the results.
do keep in mind that even if you don't rub at full lock on most terrains, you may still rub on strange slopes as i do. granted, my truck is of the older body style, but the principle still applies!
The rubbing will be minor. Most rub the control arms at full steering lock.
Thank yall! .. i think im gonna go with 33's so i still have a bit of room for flexin ..
i have 35" mt's and rub the control arms only at near full lock...i love the look and def wouldn't change them to 33" if you dont offroad or anything i would do 35's...
| All times are GMT -4. The time now is 10:49 PM. |
