F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Wheels, Tires & Brakes (https://www.f150online.com/forums/wheels-tires-brakes-29/)
-   -   Will 35's Fit (https://www.f150online.com/forums/wheels-tires-brakes/319051-will-35s-fit.html)
fx4tough07 Jan 31, 2008 03:18 PM
Will 35's Fit
I have an 04 fx4 screw and i am putting a 2.5" leveling kit on and i was wondering whether i should run 35's and 22's or 33's and 20's. The wheels i want to run are american racing black clash and either toyo m/t or mickey thompson baja atz or for the 22's i will run kuhmos. Can i fit 35's. I had 33's and 20's on my other 04 fx4 and i want to go bigger with my new truck.
Does anyone have any pics of 35's with a leveling kit??
Russ47 Jan 31, 2008 03:20 PM
ur not gonna be able to run 35's and 22's :(
chumFX4 Jan 31, 2008 03:31 PM
With only a leveling kit, you can only fit 35's on stock rims. Aftermarket rims=max 33"
wandell Jan 31, 2008 03:51 PM
Right, unless the aftermarket wheels are almost identical to the oem wheel specs. PawPaw has fit 35's using a 8 inch wide wheel with 5.5 inches of backspacing. As for size, I'd go with 20's for a 35 inch tire.
fx4tough07 Jan 31, 2008 04:10 PM
What about with a 3" leveling kit?? 20's just arent big enough on 35's.
wandell Jan 31, 2008 08:39 PM
THe CV and ball joint angles get pretty extreme with a 2.5 inch kit. I wouldn't even consider a 3 inch kit. If you like the look of 35's on 22's, by all means go for it. It's your truck and your opinion is what matters. My wifes family thinks my Expy looks crazy with 22's, but what do they know. The drive minivans and mount white letter tires on everything (yep, even a minivan once).
The wheel diameter doesn't matter with fitment, its the with and backspacing. If you can find a 22x8 wheel with 5.5 or 6 inches of backspacing you will be fine with 35x12.50-22's.
fx4tough07 Jan 31, 2008 09:45 PM
thanks wandell, ya im just ready for something new and bigger. and your expedition looks sick by the way.
Blakef-150 Jan 31, 2008 09:48 PM
For sure wouldnt put a 3" leveling kit on there.;)
fx4tough07 Jan 31, 2008 09:53 PM
Hey wandell would putting wheel spacers on make any difference??
Grubrunner Jan 31, 2008 09:55 PM
Not only is Wandell [just about] always right, but I agree with his views almost always.
The 20" wheel & 35" tire combo is a winner in just about every way.
:thumbsup:
05extcabflare Jan 31, 2008 10:09 PM
Heres my truck with 35s and leveling kit. More pictures in my gallery and modifications. "ford141"(f150online member) has 35s on 22" rims.
https://www.f150online.com/galleries...424-189778.jpg
Blakef-150 Jan 31, 2008 10:31 PM
Ive heard wheel spacers arent very safe.:confused:
maxhighlife Jan 31, 2008 11:22 PM
im running the 3" leveling kit with 325/65/18 on Helo Maxx 6 18X9 Mickey ATZ and I cut everything that can be cut plus a little more :D and it will still rub at full turn BUT I LOVE THEM they look great ROOT like a bore hog and sing you to sleep good luck :beers:
04S&BFX4 Feb 2, 2008 12:24 AM
This is a great post, I am looking at doing 35 Mud Grapplers on 20's. I am considering doing a 3" body lift though to give me that extra piece of mind. The only issue is the kit is 300 but 700 to install (4 wheel parts). I dont know how hard it would be to install on an 04 SCrew so i am kind of at thier mercy.
dre23 Feb 2, 2008 02:35 AM
Sorry, not trying to hijack this thread (but it is just really a reiteration of the OP's question anyways), but this had been my question for ages and I have received both "Yes, you can" & "No you can't" answers. Can you run a 35" tire on '07 SCrew 4x4 that just has a 2.5" leveling kit w/out rubbing or having to cut? It seems as tho our fellow member below (05extcabflare) has done this, so can someone please give me to the best of their knowledge a definitive answer. I would like my next set to have 35" tires w/either 18 or 20" rims and I don't want to lift my truck at this time...
Please chime in...thanks!! :banana: :bows: :rocker:
P.S.
05extcabflare your truck and wheel/tire combo looks badazz by the way!!
