F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Wheels, Tires & Brakes (https://www.f150online.com/forums/wheels-tires-brakes-29/)
-   -   MB predators with M/T's fitment question (https://www.f150online.com/forums/wheels-tires-brakes/308794-mb-predators-m-ts-fitment-question.html)
051fdrof Nov 15, 2007 01:51 PM
I'm looking at 20 x 8.5 MB Predators with 25mm of offset. That should make backspacing 5.25", right?
I'd like to wrap them in 33 x 12.50 Toyo M/Ts, but I'm worried about the side-biters rubbing.
Anyone?
BTW - plan on using a 2" Rancho Quick Lift
Shrkbait Nov 15, 2007 02:45 PM
25mm offset on an 8.5 wheel is actually 5.75" of backspacing. As for rubbing, you'd better wait for Wandell or someone more qualified to answer that question...
051fdrof Nov 15, 2007 02:51 PM
Center of the wheel is 4.25" + 25mm (1") = 5.25".
Shrkbait Nov 15, 2007 03:15 PM
This is where I have been going for offset/backspacing info:
https://www.rsracing.com/tech-wheel.html#backspace
or wait for Wandell, he is the guru...
051fdrof Nov 15, 2007 03:27 PM
According to that chart, zero offset on an 8.5" wheel is at 4.75", so adding the 25mm does make it 5.75", but that seems whacked. I thought that zero offset was the actual center of the wheel, which would be right at 4.25".
Shrkbait Nov 15, 2007 03:31 PM
I agree with you, its not exactly logical. I don't remember the formula, but I am quite confident the chart is accurate based on research on this forum, and all the comparison shopping I have been doing (also looking at new wheels/tires).
Bradmon Nov 15, 2007 03:36 PM
I just put Toyo M/t's on with AR trax 20x10's with a 33"x12.5" tire and the rim has 5" backspacing. I had to do some minor trimming on the front plastic below the bumper but it was only like .25" at an angle. I used an AS 2.5" leveling kit.
Copenhagen848 Nov 15, 2007 03:56 PM
As Shrkbait said, they have 5.75" of backspacing.
bluesupercrew05 Nov 15, 2007 04:43 PM
Check out the MB V-Drive rims that Discount Tire sells! They are pretty cool looking i think!
051fdrof Nov 15, 2007 05:17 PM
You're right. The formula is [(wheel width +1) / 2] + offset. Guess It's not happening. They'll rub for sure.
BGF150 Nov 15, 2007 05:25 PM
i got those same rims on my truck only with 305/55/R20 nitto terra grapplers, and i dont seem to have any rubbing issues, but it is a tight fit, the muds may rub due to the bigger lugs.
051fdrof Nov 15, 2007 05:33 PM
Any chance you could measure the clearance?
051fdrof Nov 15, 2007 07:47 PM
Hey - look what I found:
https://www.f150online.com/forums/sh...light=predator
wandell Nov 15, 2007 08:35 PM
You should be fine.
ameration Nov 16, 2007 04:34 PM
They will not rub. I have 35x12.50 R20 M/T's on the MB Predators and have no rubbing with a 2.5" AS up front. You will be fine with a 33x12.50 and the 2" lift.
https://www.f150online.com/galleries...883-196870.jpg
https://www.f150online.com/galleries...883-196882.jpg
https://www.f150online.com/galleries...883-196884.jpg
