F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Wheels, Tires & Brakes (https://www.f150online.com/forums/wheels-tires-brakes-29/)
-   -   Flat,spare tire crank won't work (https://www.f150online.com/forums/wheels-tires-brakes/301627-flat-spare-tire-crank-wont-work.html)
dunrite417 Sep 18, 2007 02:45 PM
I have read the other posts about this. The crank I have found under the hood has a bent tip, which won't lock in to lower the spare. It does not look to me like anyone has ever touched the jack or anything. I have a 2003 extended cab Lariat which I bought used almost a year ago. I have found no key for the crank. Any ideas? https://www.f150online.com/forums/im...ilies/help.gif
:help:
Bluejay Sep 18, 2007 03:03 PM
:help:
I have an 05 and it may be different. Also, only used it once and it was a while back, but I think it is the other end you use. I think the turned end is for the jack, and the receiver for lowering the spare uses a squared end.
dunrite417 Sep 18, 2007 03:11 PM
Thanks Bluejay, Kinda a dumb question but it is my first pickup. I will try it.
Bluejay Sep 18, 2007 03:23 PM
I may not be correct. I did mine at night and in the rain, so my memory may be a little wacky. Hell, it is anyways, but hopefully I'm on the right track.
