35's on stock rims ????
Originally Posted by shayden7
I have a 06 4x4 fx4 with the 2.5 leveling kit, and add a leaf. I was woundering if 35 12.50/18 will fit on my stock rims?? Also does anyone have pics of this set up?? If there is going to be rubbing where would I need to trim (front valance)?
minor rub at full lock...
Originally Posted by wandell
You'll be fine. However, I'd suggest looking at other tires. The Mud Grapplers are a good tire, but they are very loud and wear quickly. Also, the OEM 17 inch wheels are the same width and backspacing as the OEM 18's so you can fit a 35x12.50-17 (315/70-17) also.
also did you get my post to you on this thread? Really curious about your setup, It looks sweeeeeeet!
https://www.f150online.com/forums/sh...d.php?t=259954
Originally Posted by PawPaw
That's something to think about, a 35 will rub on the control arms on stock wheels. When my 35's were on my aftermarket wheels they only rubbed on the lower wheelwells. I need to get a wheel to "split the difference" and put my 35's back on!
