FX4 Tires
FX4 Tires
Okay so i called arounf to like 6 differents tire shops and none of them have the tire size i need wich are 275/65/18 the OEM that came on my FX4 they told me this is not teh required size for my trck . so just wondering what you are all running with stock rims and lift. and where are you buying tires at
They're on crack. 275/65-18 is the OEM size. Find a larger retailer such as NTB or Sears or Discount Tire. Otherwise, you can order them online from Tirerack.com or discountiredirect.com .
You can also fit a 285/65-18 with no problems, but they weigh 10-15# more than your factory size, so mileage will suffer.
Originally Posted by hivoltagefx4
My FX4 came stock with 20" wheels (which are for sale btw) I'm curious? We're the 20's an option? Cause when I bought my FX4, it seems like all the FX4's had 20" wheels on them. I don;t think I saw any with 18's? As soon as my stock tires wear out, I'll be moving up to some 33's.
Why are you selling your 20" wheels?
Originally Posted by Tripyn69
Are you looking for a whole set or just one and what type of tire is your OEM? The ford dealer should have them or at least be able to get them next day.
Originally Posted by FX4Firefighter
whiel i need two but i might as well get a whole set. what are the 33x25.00tires i see onhere what does that relat to not that size but the numbers like that
Height by width.
So the 285/65-18s wandell is talking about are 33" tall and 11.5" wide.
- NCSU
