Will 315's fit with a 3" lift
I have a 2003 F150 extended cab 4x4 off road edition. I have installed a 3" body lift and currently have 285/70/16 Yoko Geolanders on it. Will I be able to fit 315/75/16 Cooper Discoverers ATR under it. I currently have A/R 8.5" wide rims.
Thanks, https://www.f150online.com/galleries....cfm?gnum=7533 |
Yes. You will probably have to crank up the torsion bars and maybe trim a little plastic off the front bumper's lower valance.
just cranked my torsion bars no triming on stock wheels tires rub the frame and lower a arm but other than that theyll fit:thumbsup:
https://www.f150online.com/galleries...159-174126.jpg |
I don't know the difference between the '03 and the '04 as far as suspension and such, but I have been running the BF Goodrich 315/70/17 on my '04 for about 45,000 miles. I did install the 2.5" spacer on the front. I can't imagine you'd have any problems with the 3" lift.
you should be just fine unless the make the 01 supercrews higher but i don't think they do. but by the way the should fit cause i am running 315/70/17 on my f150 crew cab. i have some pics if u wana see
| All times are GMT -4. The time now is 12:39 PM. |
