picture of F150 with 285/65-18's
I have a 2004 F150 FX4 Supercrew with stock 275/65-18's. I'm considering replacing the tires with 285/65-18 tires and was curious to see how they would look...Does anyone have a picture of a similar setup?
Also... my truck is all stock, any reasons why I should not change to this tire size without other changes (rubbing, ride, etc)? any tire recommendations? I do mostly highway driving, but still want an all-terrain tire. Thanks. |
I have that set up with bfg at's and love it. No rubbing at all and i'm completly stock. I'll try to snap you a pic or two today so you can see for yourself.
I have the same exact set-up as Missouri with the same results. What you will find going from a passenger tire to a LT tire is the ride is a little rougher as the tires generally are stiffer in the sidewall.
thanks for the quick responses! looking forward to the picture(s)!
My current tire's are LT275/65-18 Goodyear Wrangler AT/S's, you think the ride will be much different if I go to BFG All-Terrain T/AŽ KO's? |
No but your traction will be much, much better with the AT KO's.
Mine is a similar set-up
