6x135 common? size recomondations?
Looking at a set of 20" rims on ebay they are listed as
20" x 9"
Offset: +30
BP: 6 x 135
Centerbore: 87
20x9 I understand 6x135 that must be the bolt Pattern, is that a common f150 pattern or is there a possibility mine are different? Any tire size recomondations where I still get decent sidewall and dont kill all the power with monster tires (ie:35's) I live on a farm and do go some offroading, I'd say 80% asphalt 20% fields/gravel roads. THANKS FOR YOUR HELP
20" x 9"
Offset: +30
BP: 6 x 135
Centerbore: 87
6 X 135 is the bolt pattern for the F150.
Ford's use the Pirelli Scorpion ATR for OEM size in 275/55/20 & I would recommend the same tire:
http://www.tirerack.com/tires/tires....nSpeedRating=S
KC-10 FE out...
KC-10 FE out...
