Rubbing Question
2006, Supercrew, 4x4, 2" Leveling Kit...
What is the probability I will have rubbing with the following wheels and tires? Combo 1 Moto Metal 951 18X9 Mickey THompson Baja Radial ATZ 325/60-18 Combo 2 Moto Metal 951 18X9 Nitto Terra Grappler 325/60-18 How much noise difference between the two tires? |
combo 2... no rubbing... no noise... have 325/65/18 nitto terra grapplers not much diffrence in noise from stock.
You don't have to worry about rubbing as far as suspension travel goes. I have 34" tires with a 2" leveling kit and I have been in numerous suspension situations and never experienced rubbing. However, there have been some instances when I have experienced minor rubbing due to full wheel turn (usually while parking and at low speeds). Keep in mind that my tires are 12" wide and the tires you are considering are almost 13" wide. The tires are very close to the control arms (with 12" wide tires). You may want to consider a slightly slimmer tire as I assume you would experience some rubbing in full turn situations.
