F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Wheels, Tires & Brakes (https://www.f150online.com/forums/wheels-tires-brakes-29/)
-   -   Will HD 20's fit on a 99? (https://www.f150online.com/forums/wheels-tires-brakes/243434-will-hd-20s-fit-99-a.html)
MouseTrap Jun 14, 2006 05:27 PM
I found a set of 00 and up 20" Harley Davidson rims and am wondering if they will work on my 99. I understand I have 12mm studs and the 20's call for 14mm. Will this be a significant problem, or is there a fix available?
Thanks for you help!
Johngs Jun 15, 2006 06:41 AM
I believe your studs are 14mm, Im pretty sure it changed to 14mm in 99, but Im not 100% on that.
Even so, you should be able to just use acorn style lug nuts instead of the stockers and be good to go if that is an issue.
APT Jun 15, 2006 07:27 AM
99 had 12mm studs. I tried to swap my 99 and 2003 wheels, but had a hard time getting the 99 chrome wheels on the 2003. No problems going the other way like you want to do, though.
wandell Jun 15, 2006 08:04 AM
They will work. You just need lugnuts for your year model truck.
MouseTrap Jun 15, 2006 08:22 AM
Excellent, thanks!
MouseTrap Jun 24, 2006 07:21 AM
Got the rims on and just got new tires, definetly need them with it being a 4x4 and all. The tires are 275/60/20 goodyears off an 06 Ram. I like :)
https://www.f150online.com/galleries...443-162353.jpg
SlammaJamma Jun 24, 2006 11:56 AM
Looks good man, but personally I would have gone with blackout, just my .02.
