Offset and backspacing?
I am interested in the Moto Metal 951's. My question is , are these rims available with different backspacings and offsets in our lug pattern or are they just produced one way? The only ones I have found so far have 18mm offset and 4.75" backspacing.
My deal is that I want my rims to stick out a good bit and I dont really think that this backspacing will do that for me. So also if I wanted a set of 36/14.50/20's to stick out about 3 or 4 inches what backspacing would I really need?
the 04-06 trucks have 5.5" backspacing with 6-135 lug pattern. The wheel you may be looking at may not come in the backspace you want(something I found out the hard way) so keep your options open. Also realize that the more they stick out the more possibility of rubbing and difference in handling.
Here are some 20" packages you can check out.
http://www.wheelsforless.com/search_...+inch+packages
http://www.discounttiredirect.com/di...vid=008441&bp=
http://adaptivestrategies.com/MOTOMETAL.html
http://www.4wheelparts.com/4wp/produ...catName=Wheels
http://www.westcoastwheelfactory.com...cts/motometal/
http://customwheel.com/custom_wheels...p/cPath/21_226
Here's a few links you can check out.
