F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Wheels, Tires & Brakes (https://www.f150online.com/forums/wheels-tires-brakes-29/)
-   -   Rotor Repalcement can't remove snap ring help! (https://www.f150online.com/forums/wheels-tires-brakes/211642-rotor-repalcement-cant-remove-snap-ring-help.html)
abeauch Sep 15, 2005 01:36 PM
I'm in the process of changing out rotors and pads and I can't get the snap ring off so I can remove my bearings. Whats the trick to get this off? I have a 93 f150 4x4 w/auto hubs. Thanks
Colorado Osprey Sep 16, 2005 12:58 PM
There are 2 snap rings, an outer snap ring on the axle stub and a inner snap ring that holds the auto hub in the spindle hub. The axle one is easy with snap ring pliers. The second one is a little more difficult. Use a dental pick to get under it, a small screw driver to keep it from spinning. Use the pick and get under it and around to get it out of the grove. I made one just for the purpose mentioned. It will need a slight bend in the tip so as it lifts the ring it can also pull it out of the grove.
good luck....it is time consuming.
abeauch Sep 16, 2005 08:16 PM
Thanks for the reply. Just in case anyone else ever does this I took an awl, bent it 90 degrees and filed it to a nice fine point. Using vice grips and a hammer I was able to drive the awl under the locking ring and slowly work it out. Not an easy job! Very time consuming. So far I have finished the rotor install and pads. I then went to install the new mile marker hubs and found out that I have to remove the lock ring and retainer ring again to install the new maunaul hubs.!! I had to bring the old rotor and hub to a local shop to have them seperated. Big job, one side done!
Padron Sep 24, 2005 12:51 AM
Most autopart stores sell a set of picks with various bends for like $5 they come in handy
Colorado Osprey Sep 24, 2005 09:17 AM
You can press out the studs yourself with a big hammer and a very large punch. Then reverse the process to install them after replacing the new rotor on the hub.
I use an old king pin.....it can chip....but be careful....wear safety goggles.
