American Racing wheels....TEFLON...???
Has anyone else seen the American Racing Wheels Teflon-coated option? I'm kicking around the idea of smaller rims and larger tires, and came across this option of Teflon coated rims.
Curious to know if anyone has any experience with them (seen or installed).
do a search here a couple of people have them on but just so you know i was going to run but i wasnt going with a lift .the back spacing is what 4.5 and offset is -25http://www.ford-trucks.com/user_gallery/displayalbum.php?&albumid=10865 they will stick out . but if you are going with a lift those and the polished/chrome are bad a$$.well good luck M.W.
The only thing I would be worried about is what they look like after a while. Have you ever looked at the non-stick surface of a teflon coated fry pan after 2 years. And that is with using all plastic utensils. With rocks, gravel, and other debris, I'm not sure the wheels will look to good after a short amount of time.
Thanks for the replies...I do like black rims on a truck (especially on AZ beige). I'm not planning on a major lift, probably just front "leveling" kit and more aggressive tires.
I've heard from others that the Teflon coating makes cleaning of fmud a snap...not bad for a guy who lives on a farm off a gravel road As for Teflon coated pots and pans--they go through extreme temperatures that I hope my tires won't (i.e. NO FIRES!! )
I don't know about you, but I like the look:
Picture courtesy of MadMarty's gallery
