Newby needs some assistance...
I am going to buy in the next 3-4 weeks a 2005 F-150 Lariat Supercrew 4x4, it comes standard with a 285/75/18 goodyear or BFG tire. I am considering upgrading the tire & wheel combo right after purchase, but would rather not lift the truck. What is the largest tire and wheel combination that I can put on this truck without a required lift? I am going to drive more on highway than offroad so lets stay with the AT versions, just wanted a little more pop to the truck. Suggestions... Thanks in advance.
Tire numbers
Are you sure those numbers are correct? That comes out to almost a 35" tire already. I think you got the profile of the stock tire incorrect. Look at your tire numbers again.
I have a 2004 f-150 extended cab 8200 GVWR and I just went to 295/70/17 (About 33.19") and would not want much more than that. It looks good now, but more would be crowded without a lift (I do have the 2" revtek leveling kit for the front.) Without it the tires I have might rub.
Hope that this helps.
David
David
