Nd help... 16x10 w/4" BS on 03 Screw? Wandell?
I have a set of Nitto Terra Grapplers in 285/75/16 that should be hitting my doorstep in the next day or so. I was originally going to go with an Eagle Series 111 wheel in 16x10, 5x135 w/4.5" BS. The place I'm going through for the wheels can't get these right now in that bolt pattern. So, I found another wheel he carries that I like but they only come in a 4" BS with the other measurements being the same.
I'm hoping these would fit since I really like the look of the wheels, but I wanted to run it by you guys here since you've seen a heck of a lot more fitments then I have. The truck is a 2003 F150 Screw 4x4 FX4 with the front T-bars cranked to level it. I don't mind trimming a little plastic up front if need be but I just wasn't sure how bad the 4" BS might be as compared to the normal 4.5" that people usually run. Would the rim in a 16x8 with 4" BS possibly be better or should I just find something with the normal 4.5" BS?
Thanks in advance to anyone who can shed some light on this for me!
