Help with offset, please!!!
98 F-150 Supercab, I'm looking into purchasing some rims. I need the rims to sit behind the wheel well as the car has air ride suspension. Could any of you recommend some details on offset to acheive that, and/or some rims that you know fit? How about a rim with these attributes:
Bolt Patter: 5-135
Offset: +25MM
Any help is appreciated! Thanks in advance!
Justin.
Bolt Patter: 5-135
Offset: +25MM
Justin.
not sure, but what does air ride have to do with it setting so far in on my 99 4x4 reg cab short bed i have 16x10s i believe they are4.5 bs and not sure any more the offset and they do stick out a little bit (see my gallery 40/99/04trucks)so 8.5 should be close to flush with the wheel well. hope this helps M.W.
