lug pattern on '00 F150
if i were to look for rims on ebay, what is the lug pattern on an 00 f150, i know its 5 lug but whats the space inbetween?
They are a 5x135mm with a 14mm lug. 97-99 had 12mm lugs, so they may not fit.
Also, these wheels are hubcentric, so the center hole must be the right size. I am not sure what that is. |
Ford's are the only vehicles to use a 5x135 bolt pattern, so if the bolt pattern is correct the hub size should be the same as well.
