tire pressure
Any suggested tire pressures out there for a 305/70r16 Nitto Terra Grappler mounted on 16x10 wheel? Mostly city driving.... :banana:
Keep your pressure at about 35 psi. Will maintain a smooth ride and help a little with your MPG.
I run 38 psi in my BFG's. You should be fine in the 35-40 psi range.:thumbsup:
35-40 is good, although you will probably want to keep the rears a little lower (2-3 PSI) so it doesnt bounce around as much in the back (also helps in the rain).
Great . Thanx for the input,Ive got them at 35psi now and seem to be fine. Pics soon....
I had 30 in my front for 3k miles and it wore the turd out of the sides. 35 is min i think
285 60 18 grapplers. |
i run mine what is recomended on the side of the tire,(35PSI)
