how does this sound
how does this sound
hey guys, i just wanted to share my plans to see if anyone had any advice for me:
305 or 315 BFG on 16x8 rim
exhaust
headers (pace setters?)
*pulleys or gears, i need help there
3 inch body lift
cold air intake
throttle body
little things:
clear corners
billett grille
window tints
*im stuck on the pulleys/gears because i hear with larger tires the tranny is stressed a whole lot more, someone told me id be alright but any advice would help
exhaust
3 inch body lift
cold air intake
throttle body
little things:
clear corners
billett grille
window tints
with 305's, i see no reason to regear. with 315's i would, but you don't have to. for more info on some pulleys, check out www.troyerperformance.com to get a look at some. They give you a whole write up on the benefits and drawbacks of the pulleys.
~Colby
I thought regearing a 4x4 cost about 1200 bucks. Anyway, I don't think he will have to regear to run 305 with all of the performance mods he is doing. It's only a 33" tire, so wouldn't going to say, a 4.56, kill his mileage? I have 285's which is also a 33, and with a cat back and k&n my performance is still better than it was stock. I realize that the 305 is 12.5 inches wide and the 285 is 11.5 inches wide; that wouldn't make that much difference, would it? I'm not trying to prove you wrong or argue with you, just wandering for myself as well.
Your right, he can run stock gearing. It will lose a slight bit of get up, but it shouldnt be to noticeable.
My point about gearing though is that it will really give you some bottom end get up, my experience is that you will feel regearing more than any of the other bolt ons. Some say you might lose a mpg or two, but to me it isnt significant. My friend regeared with 33's to 4.56's and man, it was a whole new truck! He only had a 4x2 though, so it is ALOT cheaper! His mileage actually went up, and from what he figured, it was do to it being undergeared with stock gearing for the size of tire that he put on.
You wont need to, but in the future it would be something I would look into!
~Colby
Originally posted by APT
Spend the money on a tuner before pullies. You'll get more performance, and they can adjust your tire size to which will correct any potential problems with the tranny.
I've seen lots of new trucks on the Ford lot for sale with 285 bfg's right from the factory with Waldoch packges, which is 33in. tall, so how bad could it be going to a 305 or 315?
In fact my local dealer has a new '04 down there now with a pro-comp lift and 315/70/17 bfgs. It's all decked out. It's got the 3.73 gearing.
So that has me thinking that even with 3.50, which is what I also have, it shouldn't be that big of a leap to run a 315 without a gear change, especially with some performance mods and the tuner.
You guys agree?
I had stock 3.55 and 315/75/16 tires. I regeared to 4.56 and my power went up and my gas mileage went up very slightly. I also have a superchips tuner and that is great for fixing the speedo and adding more performance to the truck. As long as you follow directions you cant mess your truck up. Its pretty easy to do.
