Can I put 35x1250x16 on 4x4 1997 4.6 larate?
Have Trailmaster 4" lift,Have 33" Tires now,What do I do to put 35"? What are the Pros.And Cons.?
The 35s should fit with your 4" suspension lift. You might possibly have to dial up the front torsion bars a bit and possibly trim the front valance just a little bit, but they will fit. One pro to bigger tires is they look awsome. Another is that you get more ground clearance. One big con is that you will want some deeper gears to go with the bigger tires. You will probably want 4.56 gears with 35's. Other than needing lower gears that is the only problem with the bigger tires that I can think of right now.
------------------ 1997 F-150 Lariat Ext Cab Short Box 4x4 Off Road Package 3.55 Gears 265/75 R16 Uniroyal Laredo M/Ts My 2 cents worth If you're gonna stroke it, POWERSTROKE IT!!! |
