Brake Booster??????
Brake Booster??????
Does anyone have the tsb numbers for the F250LD brake booster upgrade, or is this just a myth that it will help?
I've talked to some people that have had similar experiences with the rear brakes not working on Dodge 3/4 ton trucks, and they swapped in the 1 ton rear cylinders, and their problems were solved.
I researched this for the F150, and the rear brake cylinders for the F250LD are the same size.
I guess if there are no tsb numbers I will have to adjust the rear brakes every week due to the poor automatic adjustment feature.
I've used the search button, and no numbers found.
Thank you in advance for replys.
MIKE KIEVIT
1997 F150XLT 4.6l 2WD(2ND OWNER)
Standard Cab
Mcwelco Tool box, 2000 aluminum wheels.
Rough Country 2 inch leveling coils.
Added another intermediate spring to rear springs for 3inches of lift and still a cushy ride.
RS9000 Shocks.
MIKE KIEVIT
Standard Cab
RS9000 Shocks.
Location: Houston, by way of every major city in America.
on
This is the first I've ever heard of this. Will a booster from any year(97-up)work?
Or do you have to use the same year model? Sounds like a cool upgrade,either way,,,,,98
98 F-150 4.6 Litre XLT 4x2 Ext. cab
prarie tan/tan int.
Yep,it has alot of stuff installed on it,I just got sick of lugging that huge sig. around,hehe
Come and see my newest pictures@ www.my-f150.com
Everything is shown there,except for the Superchip,Thanks Mike T!!
FENDER GUITARS ROCK!!!
Now,if it only looked like this in real life
prarie tan/tan int.
My dealer told me there was no S.B. for the 2000 model year but there was for the older trucks.
My booster died at 29,000 miles and was replaced under warranty with an "updated, sounded like BS to me" version. No problems since.
2000 XLT supercab, 4x4 7700lb. package, 5.4L, 3.73 LS, 265 BFG All Terrains on Epic 16x8's, skids,rear sway-bar,Rhino brush gaurd,KC Daylighters,CD changer,MagnaCharger, Flowmaster,Superchip, Airaid, Replaced the JUNK Gibson Headers with Jet Black coated JBA's, Captains with Expy console, Island Blue
