Oil seeping every where
Has anyone else noticed oil seepage from their oil pan or valve covers? I changed oil yesterday and noticed that I have some wetness around these areas. I checked the fasteners and they are tight.
------------------ 1999 F150 S.Cab 4x4 Northland Edition,5.4 Off road pkg. Fleetside Black w/grey int. |
My 99 with the 5.4 had a head gasket leak on passenger side. Truck had 33,500 miles. Dealer replaced both heads and gaskets. Seems to have fixed problem. They told me job would take 2-3 days. Got truck back after 3 weeks on May 16th. This has been a very common problem with the 99 5.4. Good luck with yours.
does it ever end??????????????
------------------ 1997 F-150 XLT 4.6 REGULAR CAB, FLARESIDE PACIFIC CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD). Better 1/2 : 92 Red T-Bird. |
First off, Bob, how often do you degrease/wash your engine?? I do mine every other time I wash my truck. No engine will ever be completely oil tight. Especially since your running a 99, it will show a little wetness around the gasket joints. All engines will. Shouldn't get to the point of dripping though, not at least untill 100k miles, but all engines will show wet signs around gasket joint. Let's set realistic expectations here.
------------------ - 2001 F150 Harley Davidson Special - 1993 Mazda Miata, wifes car - 1994 Harley Davidson Heritage - 1976 Honda CB750K, Original - 1965 Honda 305 Dream, Original - 1971 Triumph Trophy 650, Original - 1971 Norton Commando - 1970 Honda Trail 90, Original - Yamaha 500 Short Tracker, racing #69 - 1984 Yamaha Virago 1000, wifes bike - 1981 Honda Passport 70, wifes bike |
I suppose I do have pretty high expectations from a 30k truck. I’m pretty picky about my vehicle as most of us are. Though I don't plan to get it fixed unless it gets to the point of dripping. This engine only has 30,000 miles on it since I had the original replace due to piston slap with a new 2000 engine. I’ll degrease the engine and watch it for now. Thanks for the replies.
Your expectations aren't high. In this day and age anyone should be able to build a motor that doesn't leak like the 5.4's.
Texaco wanted to set up an oil rig on my engine block!! I guess I know what to look forward to. Mine has been at the dealers for the last 3 weeks getting the FQR put in. I guess in another 30k it'll be back in. ------------------ 1999 F-150, 4x4ORP, 3.73LSD Toreador Red, Superchip. |
