F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   are all 351w's the same? (https://www.f150online.com/forums/v8-engines/84898-all-351ws-same.html)
Donate54 Jul 26, 2002 11:46 PM
im considering a 351w swap into my truck and i havent found any 351w's that have been pulled out of trucks, but ive found some that have been pulled out of passenger cars (crown vic., etc). are these the same engines as the ones in trucks? i know cams and intake manifolds and some other misc. parts might be different, but are they essencially the same? another thing, if the 351w was originally carb'ed, can i switch it to efi with no problem (as long as i have all the parts, of course)? thanks!
ps. im talking about the 351w's only, not the 351C or M
GooberPHX420 Jul 27, 2002 05:13 AM
Ive got a 351 in my bronco and it's a beast. Be prepared to dig deep for that extra gas money.
Donate54 Jul 27, 2002 10:10 AM
if you dont mind me asking, what kind of mpg does your bronco get and what are its specs? im curious because the fuel consumption is the only thing holding me back from the 351. thanks!
GooberPHX420 Jul 28, 2002 01:31 AM
Donate - I get 6mpg. Now - this IS NOT the norm. When it was running healthy, I got about 9 around town and 14 highway.
Note: Motor has 149k on it, so I dont expect much more than it to run. LOL
Donate54 Jul 28, 2002 11:08 AM
dang, i get 10 town and 15 highway right now. ohh well, if i wanted economical id get a honda :cool:
PKRWUD Jul 28, 2002 12:30 PM
I may have already covered this elsewhere, but I'm not positive, so I'll say it again:
Starting in 1994, the 351W became a roller block. While you can use pre-'94 flat tappet cams and lifters in a roller block, you can not use a factory roller cam and lifters in the pre-'94 block, unless you install a conversion kit, and even then, you are usually limited to the cams made by the company that made the conversion kit.
Take care,
~Chris
