Engine difference
I have the 4.6L V8. I noticed whenever I look up oil filters, air filters, sparkplugs, etc. it asks if the 8th digit of the VIN code is a 6 or W. Whats the difference between these 2 4.6L V8's? The 8th digit for mine is a 6. I've heard that the 6 is rarer than the W.
1997 XLT Teal 4.6L Flareside 4x4. Automatic, Reg. cab, tinted windows, bug deflector, Dual exhaust, K&N Generation 2 air filter, BullDog keyless entry/remote start(installed myself), Custom 16" wheels, bedliner, Covercraft tonneau cover. Going to add headers.
I think one is a manufactured in Windsor and one in Romulus-my guess w=windsor. I looked this up one time due to a thread dealing with piston slap on this site-you might check it out. BTW-the Romulus (that it looks like you have) is not subject to the piston slap problem.
<font face="Verdana, Arial" size="2">Originally posted by King James:
</font>
</font>
HI!... The WINDSOR and ROMEO 4.6's also have different valve covers. The bolt pattern on the valve covers is different. By the way the ROMEO 4.6's also have the PISTON SLAP problem. There are a lot of them around here.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
I think I have the Windsor model. It says something about Windsor on the valve covers. How would I know if I have the problem? Is there a recall for the problem? If there is, how can I find out if mine is included?
W = Romeo
6 = Windsor
(Ford did this to throw you off the trail)
From what I understand, you won't have any doubt that you have piston slap. On a '97 I would guess that if you don't have it by now you shouldn't lose any sleep over it.
1999 Ford F150 Lariat RegCab shortbed 5.4L 3.55LS Towpkg Line-X
15.714@85.21
6 = Windsor
15.714@85.21
