coolant problem
If you were getting oil from a head gasket leak the oil would be floating on top. If it's all grey it's probably just dirty. Sediment likes to settle in the bottom of the resevoir. How does the coolant in the radiator look? Maybe it's time for a flush?
-Jon
-Jon
Grey is not good. It really sounds like oil. Look closely at some of the coolent, does it seem oily? Check your oil, see if it shows signs of coolent in it. If so, you probably are looking at a blown head gasket, far too common in the 5.4.
Hey guys , my 91 f 150 5.0 has water in the oil, the water looks to be fine though. the engine runes the same and dosn't make any different noises. head gasket? it has 120,000 on it, maby i should just look for a new engine. about how much would i be looking at for a good used one 5.0 , 5.8 thanks alot ,
John Reed
John Reed
