F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   Can't figure it out (https://www.f150online.com/forums/v8-engines/524134-cant-figure-out.html)
Quickpick Jan 21, 2021 11:03 PM
Can't figure it out
I have 04 f150 4.6 230000 miles rough idle soon as you give it any gas it planes out .getting a lean in bank 1 code .so I pull and check every vacuum line clean the mass replace plugs coil packs even new intake gaskets pressure tested lower plenum and put new throttle body all for nothing I am almost ready to set it on fire.somebody please help me or bring on the gas caused I am at a loss
stoffer Jan 22, 2021 08:15 AM
did you change o2 sensors?
what is the TPS adjusted to?
what was used to clean the MAF?
what spark plugs did you use what did you get them to?
what coil packs did you use?
is this a new development or something that just started happening after a recent modification or incident?
Quickpick Jan 22, 2021 08:23 AM
I used maf cleaner but didn't change so I replaced it to o.the 02 sensors seem to be working fine I watch them and my fuel trims to see if there are any anomolys.the long term fuel trim on bank 1 is staying around 26 .that's the bank I was getting a lean code on
stoffer Jan 22, 2021 09:42 AM
because it’s one bank and not both
that eliminates the MAF
have you checked the fuel rails / injectors for blockages / damaged injector wires??
Roadie Jan 22, 2021 10:19 AM
What is the short term fuel trim on bank 1 when it smooths out and when it is revved up? If it is normal when revved up, there may be a vacuum leak. You can carefully use an unlighted propane torch to check for leaks or better yet do a smoke test. Chris Fix has a video where he used a shop vacuum to blow up the exhaust pipe and spray soapy water on the potential vacuum leak areas and look for bubbles. It may be time to get a professional involved.
