98 cam saft
Old 10-14-2018, 05:20 PM
Leno123's Avatar
98 cam saft
99 expedition 5.4 2v. will the cams form a 98 5.4 2v with d hole cam lock work on my 99 engine and will it run right?
Old 10-14-2018, 06:22 PM
glc is offline
The Ford parts catalog uses identical part numbers for those 2 years.
Old 10-14-2018, 07:21 PM
Leno123's Avatar
How does 99 cams compare to 01 5.4 expedition cams? Im building 1 motor from parts of 2. Cams have different end on them. 99 cams I have has hex pointed holes in end. 01 motor cams I need to use have d shaped hole in back end.
Old 10-14-2018, 09:03 PM
glc is offline
Go to tascaparts.com, select a vehicle, go to Engine, Engine Parts. You will see the camshafts along with part numbers. The 2001 SOHC 5.4 cams are the same part numbers as the 98 and 99. Why are they different? I have no idea. Note that the 4.6 Windsor cams are the same, but the 4.6 Romeos are not.
Old 10-14-2018, 09:08 PM
Leno123's Avatar
Will check out numbers to see what i actually have. Will the romeo cams work on a winsor motor?
Old 10-14-2018, 11:04 PM
glc is offline
No, they are different. That's what I said.
Quick Reply: 98 cam saft
