1993 Ford F-250 351w timing issues
Old 01-13-2018, 01:05 PM
Matthew Clyncke's Avatar
Hey so I am having issues with setting the timing on my 1993 f250 351w efi. I am unclear as to when the timing should be read. My question is that at idle with the spout plug out what degree should it read? Some people have told me it should read zero, which is what it reads now, but online I have seen a lot of people say that at idle it should read between 5-10. Any help would be appreciated, thanks
Old 01-13-2018, 04:47 PM
masseyman's Avatar
Ten degrees BEFORE Top Dead Center. !0 degrees advanced with the spout removed is the recommended setting.
Old 01-13-2018, 04:53 PM
glc is online now
10 BTDC is the book setting, you can go as high as 16 BTDC with higher octane fuel. Regardless, if you get spark knock it has to be retarded.
Quick Reply: 1993 Ford F-250 351w timing issues
