150,000 miles. What needs to be done?
150,000 miles on the 2007 F150. What needs to be done?
What has been done already? Plugs, COP boots, fuel filter, air filter, coolant, and transmission fluid. Check front end for wear. Change shocks if over 75,000 on them.
Somewhere around 130k miles, my 02 needed new front bearing hubs and the RR bearing and axle replaced as well as brake calipers and flexible brake hoses to get rid of sticking brakes. I changed the master cylinder while I was at it. It also needed new front sway bar bushings, tie rod ends, lower ball joints, and idler arm.
