Can't get #4 plug on 5.4L 3V
Swapping my plugs this AM, and ran into a roadblock of sorts. I can't get the plug closest to the firewall, passenger side. I removed stuff to get better access. But I can't get the socket to seat down onto the plug. A bit odd, but is there a trick or something I should be trying?
This is the 2008 version with the SP-509 plugs, the shorter one piece plugs, redesigned heads, if that matters. I am hoping that I found my misfire issue though, the #3 plug anode was bent, basically gapped about twice as far as should be. |
Get something pointed and sharp. Dig in around the plug and then blow out the hole. It's probably dirt and debris.
Thanks, I did blow out the tubes but will try again. It's odd, I just can't get the socket down onto the plug.
Waiting for it to cool down now. I had to stop half way through the job to go run somewhere. I got 1-3 and #5 replaced before bolting it all back together. It does seem to have fixed the OD low RPM shudder/ miss. I was skeptical that this was an ignition/spark issue. I was hopefully wrong! |
It's possible there's something else down in the hole
Generally blowing air down there is sufficient You might be able to use a smart phone camera back there and take a picture down the hole and verify? |
I held a motorcycle mirror and a flashlight back there just to make sure there was a plug in there! I can see the top of the plug. I might try to get a better view. There was a lot of dirt around the head, but I blew everything out. Might try to give #4 another blast. Waiting for it to cool now.
OK, got 7 out of 8 plugs swapped.
I think I figured out what's wrong with plug #4. Tube dull of dirt. That went downhill fast! |
Finally got it!
Yaaaay!
I was super skeptical but new plugs cured the low RPM bucking in 4th gear.
Sweet! A little persistence paid off :rocker:
| All times are GMT -4. The time now is 12:05 AM. |
