I hope so too. What a pain to change out though.
Jeff
Originally Posted by 2001SuperCrew4x
(Post 5176659)
2001 Supercrew wth 5.4. On Thursday leaving work it act acted like it was out of gas truck finally died would not restart but would turn over. I know it was not out of gas but I added 5 gallons from work truck started right up and drove 20 miles parked it for the night started up started up just fine in the morning drove another 20 miles parking for the day. Drove to work this morning parked it in the shop went to leave act like its out of gas again I know it's full of gas because I filled it up yesterday. It will start up and run for a bit and then die. Does it sound like a fuel pump issue or maybe some bad gas? I bought a fuel filter so when I get to work tomorrow I will try that as the truck is still there. Any help would be greatly appreciated.
What year?
It should be easy to check the fuel pressure if your truck is a 97 to 03 at the shrader valve on the fuel rail.
I'm guessing it's a 2004+ because he talks about a module by the spare tire. That would be the FPDM which needs to be removed and checked for corrosion.
