1995 f150 xlt
I have a 95 f150 xlt that turns over but will not start...I was told that its not getting any fuel or spark! I have had the coil replaced and the module checked an they both are good...what should I try next???
fuel pressure test.
Thanks...I was told to change the fuel pump
well If its me I test it first.
The fuel pump was definitely out...and now I have changed it as well as the fuel filter, plugs, coil, and module and it still won't fire up...wat should I check next??
Do you have fuel pressure now? Do you have spark now?
Yes I have fuel pressure but no spark...I took the #1 spark plug off an put it against the exhaust manifold while turning the key an got no spark
figure out if the coil is getting power and sending spark to the distributor.
