engine noise 4.6 L
blown sparkplug replaced now major rattling noise both sides. sounds like not running on all cylinders.2008 4.6 f150. any advice.
Originally Posted by tritonowner
(Post 5120864)
Job 1: get codes read. MGD |
What process did you use to replace the blown spark plug?
Originally Posted by MGDfan
(Post 5120873)
:welcome:
Originally Posted by DYNOTECH
(Post 5120876)
(Post 5120893)
Thanks for the info. Engine light not on mechanic checked codes reading everything ok. Plug that was replaced was badly worn almost no electrode left if other plugs worn this bad wondering if replacing all would be next step or a waste of time and finances ?
First - no light does not always mean no stored codes are present. Second - if ONE plug was worn, it's almost a certainty the others are as well. Third - please answer Dynotech's question. Thanks MGD |
Sorry new to forums And almost computer illiterate lol. Will take a bit to get used to. thanks for any info and patience.Mechanic did read computer and no codes present. Was tapped and sleeved not sure what kind he used .
(Post 5120901)
No worries, mate. Would it be possible for you to find out which specific method he used? It is important. As well - could you please ask him ( nicely of course ) if he examined Mode 6 misfire count data ? The persistent rattling sound is troubling - I would elect not to drive it much pending further diagnosis to ensure no more damage is being done. Thanks, and Good luck. MGD |
