5.4 2v lightning build
I have a 2000 F150 5.4 2v. My truck has 270,000 miles on it so I know I'm gonna need a new engine eventually. When I put a new engine in it I want to go all out. I want to put a lightning svt supercharger on it. I know that I need 11cc dish pistons, a high flow oil pump, upgraded water pump, either a forged or lightning crank, new cams(thinking comp cams xtreme energy 2v cams), and of course the super charger. I'm gonna put a 4r100 tranny in. What else is needed? Injectors? Do I have to do anything with the valves? Will there be any modifications needed to make the supercharger bolt on? Any help would be GREATLY appreciated. I want to start the build next month.
Bracket with idlers and special bolt spacer (washers will work for a spacer or simply run without it)
Tensioner Assembly Lightning Alternator (Lightning / Harley truck specific to clear the turkey pan) Alternator Stabilizer Bracket Intercooler Pump and Pigtail (Bracket NLA the pigtail can come from an injector harness) Intercooler Reservoir with Cap NLA IAC Tube Available Throttle Cable Throttle Cable Bracket Cruise Control Cable NLA IAT Sensor (fits in air cleaner) Available Water Pump Spacer Available PCV Tube (left hand side) Available TB to MAF Rubber Connector with clamps Available 90mm MAF Available Intake Gasket Set Available In-Tank Fuel Pump In stock Upper Radiator Hose Upper Two Intercooler Hoses NLA Original Equipment Installation Bolts Available Drive Pulley with Belt (Boost level of your choice) |
