'04 5.4L needs replaced. What parts would you use to build a strong motor?
So it has finally come time for my '04 S-crew with 190K to have a heart transplant.
Bought in October 2011, changed most fluids except transmission and transfer case. I change oil at the 5k mile mark these days in my vehicles. Maybe that isn't good to do. LOL.
Changed oil a couple times till:
In May 2012 had to replace driver side 'cam phaser actuator' because it was severely gunked up. Ford recommended doing oil changes every 1k miles for 5k miles to clean the engine up. And also use one quart of tranny fluid with every oil change.
After that I continued for the next year with regular oil changes at 5k miles and cooling system fluid change every 25k miles.
Currently the engine is in a sick state LOL, and time for replacement. We have been trying several things to clean up this sludging and coked on oil, as well as tried a few replacement parts that arent' gunked up. So with future horsepower and bolt-ons in mind, what parts would some of you recommend? In the future I plan to add a small roots type blower(Kenne Bell or Roush probably) and exhaust...there are tons of exhaust choices.
So with the truck being a daily driver and future horsepower in mind I'd like to hear some suggestions for building a strong short block.
Thanx
Chris
EDIT: Oh and here is a pic of the passenger side cam phaser actuator.
Thanx
Chris
best bolt on i found was a 75mm tb huge differance but i had to grind the intake down a little i would go with a 70mm. but without headers and intake its kinda pointless. got to have exhaust to let the air thats comeing in out. so i got a cai and long tube headers biggg dif gas and power. i got a couple other things done as well gforce chip and edge programer iridum plugs and head work but thats a pain in the a$$ to get done and expensive.
Oh. That phaser solenoid looks a little erm 'Gunky'
I have a Manley bottom end here in a crate. Factory forged crank.
Jut keep an eye out for Pistons & Rods. Make sure you get ARP2000 bolts in the rods.
Gotta get it machined. The Manleys will need a couple grand clearance over stock pistons.
There's a few guys looking to go built, a JDM bottom end is probably a good idea if you don't want the leg work. Just beware of budget bottoms ends as they tend to leave out quality fasteners etc etc.
Did actually get started till Tuesday. But motor is out. Good grief what a pain in the rear. Ford really should attach 127 MORE things to the engine....LoL, and hide them better. I was able to get everything unhooked except one bracket on driver side head...which I didn't see till engine was most of the way out. Ha ha ha.
