Changed spark plugs now running very rough
I finished changing the spark plugs in my 2007 F-150 (thank god I didn't break any plugs). I installed all the coil packs back in the same position, started up the truck and now it is running very rough. I am not getting any check engine light. Is there a certain amount of time for the computer to reset itself? I have only let it run for about 5 minutes. Is there anything else I need to do?
Recheck
IF it's running poorly, the you missed something. Recheck the injectors electrical connections, Recheck the COP's electrical connections, Check to see that you have all the vacuum lines connected. The final problem is that you might have too much dielectric grease on the actual COP spring. Pull all the cops, clean, grease and pull the spring tips out and clean. Reassemble the COP's
OP I would have to think you either got one of the COP boots not on the plug as they can go down onto the sides of the plug sometimes upon reinstall or you have one of the cop connectors or injector plug connectors off or in the wrong position go back and recheck all terminal connections. And like Jbrew said make sure you are using Motorcraft plugs.
No, that's incorrect technically. A pack is plural, meaning more than one. Hence, -coil pack; the part operates multiple cylinders. A COP system use individual coils. Singular, COP; one dedicated coil per cylinder (one part). Therefore, "pack" is non existent with this system.
Nowhere have I found COP systems within Ford literature referred to as coil packs. Coil packs were used on the earlier 4.6L's and 4.2L's. That is where coil "packs" enter and then exit the picture.
COP systems as a whole, are referred to just that, -COP systems.
I'm pretty sure I got it right. As far as HIS meaning, - you may want to go over that again Richard... Yea, -that should be straightened out as well.
What??
So the way he was referring to all the COP's together they were in multiples. He did not say I replaced each COP he refereed to all of together.
So now instead of being the correct pronunciations **** maybe you can get back to helping him instead of trying to correct everyone's meanings. Sometimes giving people the correct terminology is best left to be done privately in a PM as to maybe not embarrass them in public, especially a noob who you could possibly make not want to come back due to the way you spoke towards him.
I am offering assistance,- as soon as the OP confirms the use Motorcraft plugs. It was left at that. You are offering incorrect terminology, -not all incorrect, but your going outside of what the OP was actually referring to. Of course this is trashing the thread; for what ? That's right, protect his feelings I guess. Must be more to it.
When you change plugs on a COP system, it's usually a good idea to replace all the COP boots - they are available separately and are relatively inexpensive. If you replaced the plugs on a 3v with anything but OEM Motorcrafts, you HAVE to change the boots, the old boots won't seal properly on the different plugs.
Motorcraft WR6131 boots are $6.10 each at rockauto.com.
Yep, I have been around here for a long time despite the low post count. There are a good amount of us original members that got that join date when something changed many years ago. This site was not as popular back then and I was in and out randomly but active on a different ford truck site. That site went downhill a few years back, Then I got the mustang and spent a couple years at a few Mustang sites but have always been lurking here and just became active again several months ago.
By the way, who cares if he said coil packs? An extra letter (s) doesn't change the fact that he knows what he's dealing with and made sure to hook it back up correctly. I am big on accuracy, but this seems unnecessary. I would assume he knew what he had removed/installed...
I have the same problem, I had someone change my plugs lastnight now my truck is shaking. I hurd I might have to reset my computer and that Auto Zone can do it for me. Is that true?
Right, if the problem started after the tune-up, something is awry. Check all connections and make sure plugs are tight (not overtight...).
