F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   Help! 97 F-150 4.6L truck won't start! (https://www.f150online.com/forums/v8-engines/469232-help-97-f-150-4-6l-truck-wont-start.html)
txkc24 Apr 7, 2012 06:32 PM
Truck was running okay... but decided on a "tune up" since the odometer is stuck at 216K miles since I bought it last May. Also removed AC Compressor and installed bypass pully since the compressor was locked up and making a terrible noise.
Changed the plugs and wires, checked 3 times to make sure the wires are routed according to all the diagrams I could find. What else could possibly be wrong? It's turning over, but just won't start. The old plugs were ground down to nothing, so I would hate to re-install them.
I am cross posting this because I need drive to work on monday! Thanks everyone for input!
glc Apr 7, 2012 10:18 PM
What did you use for plugs and wires? Make sure everything you disconnected for access is reconnected, and look for things you may have knocked loose or broken.
jbrew Apr 8, 2012 06:56 AM
Did you disconnect the battery first ?
DYNOTECH Apr 8, 2012 08:39 AM
When you removed the A/C compressor I bet you accidently disconnected the HDR sensor connecter as it is right behind the compressor on the front cover. If that connection is loose or disconnected the engine will crank all day but not fireup.
txkc24 Apr 9, 2012 06:59 AM
I don't think we disconnected the battery first, but we have disconnected it since trying to "reset" the computer. We have now taken the new wires off, put old ones back on. Still no crank. Next step is to take all the new spark plugs out and put the old ones back in. DynoTech, I know we did disconnect a wire near the front case because it's right in the way of the new pulley, but we've since plugged it back in. Thought it might be some type of oil pressure sensor... could we have messed up this connector unplugging it, and could a replacement be bought if so? it seems to Y off from the ac compressor switch, which isn't connected to anything.
Plugs: Autolite Platinum, Wires: Borg Warner (bought at O'reillys)
Is this the HDR Sensor your referring too? I will gladly pay $25 for this part, and put my new spark plug wires back on.
http://www.oreillyauto.com/site/c/de...osition+sensor
txkc24 Apr 9, 2012 07:18 AM
UPDATE! I just got under the truck... 6:17am... I'm an accountant, and that cam sensor switch is all kinds of tore up. My boyfriend will be replacing that this afternoon! THANK YOU!
But it still Y's off from the AC compressor switch which is dangling, and it seems like it's right in the way of the pulley if plugged in right... any ideas? I took some really bad pics... but you'll get the idea.
http://www.facebook.com/media/set/?s...1&l=6d1740d491
jbrew Apr 9, 2012 07:46 AM
Yea, it DEFINITELY will not start if the CPS is not connected properly.
Also, -you disconnect the battery before a plug swap to keep from possibly frying the PCM and other electronic components.
DYNOTECH Apr 9, 2012 01:39 PM
The picture that OReillys has is of a cam sensor even though it says crank sensor. Same idea but your crank sensor will have a 45 deg angle for the connection instead of a straight one as shown. Yes you want a CRANK sensor (HDR) not a cam sensor and that is the no start problem...The cam sensor is on the top driverside front cover under the coil pack. Just so you don't get the wrong part if needed. No connection or bad connection there and no start. Just use some plastic tie straps to fasten the wire up away from the A/C and serpentine belt. Good job young lady!! Happens sometimes when the A/C compressor is replaced.
jbrew Apr 9, 2012 02:08 PM
Right, look here. Same on your engine -
http://autorepair.about.com/library/...bl732a-lib.htm
_______________________________
https://www.f150online.com/galleries...943-213711.gif
Item Part Number Description
1 9F715 Idle Air Control Valve— (IAC) — 4.2L Vehicle
2 9F715 Idle Air Control Valve— (IAC) — 4.6L, 5.4L
3 — Cylinder Head Temperature (CHT) Sensor — 4.6L, 5.4L
4 (ECT) — 4.2L, 4.6L12A648 Engine Coolant Temperature Sensor
5 (TP)9B989 Throttle Position Sensor
6 — Fuel Pressure Sensor
7 6C315 Crankshaft Position Sensor— (CKP) — 4.2L Vehicle
8 6C315 Crankshaft Position Sensor— (CKP) — 4.6L, 5.4L
9 6B288 Camshaft Position Sensor— (CMP) — 4.2L
10 6B288 Camshaft Position Sensor— (CMP) — 4.6L, 5.4L
11 12A362 Camshaft Synchronizer— — 4.2L
12 12A699 Knock Sensor— (KS) 4.6L
13 12A699 Knock Sensor— (KS) — 4.2L[/QUOTE
__________________________________________________ __
https://www.f150online.com/galleries...4-794-6965.jpg
RedTubey671 Mar 4, 2014 06:20 PM
So where is #3 (Cylinder head temp sensor)??
jbrew Mar 4, 2014 08:40 PM
Around the center of the pic, -white in color and only half exposed, -
DELETED
RedTubey671 Mar 14, 2014 03:30 PM
DELETED
Was there an attachment, or was this in reference to the pic from before?
