F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   V8 Engines (https://www.f150online.com/forums/v8-engines-24/)
-   -   Please help...won't stay cranked (https://www.f150online.com/forums/v8-engines/461992-please-help-wont-stay-cranked.html)
cnt487 Dec 11, 2011 05:42 PM
Replaced the fuel pump 6 months ago and have no problems with it since. Yesterday while driving it all of the sudden lost power as if it was running out and shut off. Battery is fine. Fuel pump is priming and sending fuel to the fuel rail. Checked all the fuses and relays and they're all fine. Now I'm at a dead end and not sure where to look next. Could it be an electrical problem or is it possible that after it turns over that the fuel pump could not be sending enough gas? Got it to crank today for about 3 seconds and it started chugging like it was running out of gas again and cut back off. I'm putting some gas in a can on my way home and trying that just in case my gauge isn't accurate, I'm pretty sure it is though. Any direction would be greatly appreciated!!!! :)
glc Dec 11, 2011 06:17 PM
Hook up a fuel pressure gauge to the rail. Less than 28 psi = no start. How old is the fuel filter?
cnt487 Dec 11, 2011 07:00 PM
Fuel filter was replaced when the pump was. I'll check the pressure and see what it is. What if it isn't 28psi...what would I need to do next to fix that? Does that mean its the fuel pump not sending enough? Thanks btw!!
glc Dec 12, 2011 04:20 AM
Could be a bad fuel pressure regulator.
cnt487 Dec 15, 2011 12:45 PM
Replaced the fuel pressure regulator and still no go. Possible the pump is defective?? Also, if my ignition coils were bad would it cause it not to crank and actually cut off while driving?...which is what happened. I'm thinking fuel cuz of the cut off during driving, but then again I don't have a clue or I'd have it fixed already. :D
enriched Dec 16, 2011 06:37 AM
is the anti theft light flashing on the dash?
JCR 56 Dec 16, 2011 06:53 AM
Have you ever checked the fuel pressure like was suggested earlier?If the pressure is good it's probably not the pump.
cnt487 Dec 16, 2011 11:36 AM
Don't have an anti theft light flashing, dont think I even have one of those. Checked the pressure after the new regulator and hardly no pressure at all. Removed the six month old fuel filter and it was pretty nasty. Turned it over with the filter off to see how much fuel the pump would pump out and not much at all. Thinking the 6 month old pump could be defective? Gonna work on removing and replacing it under warranty asap. Can't think of any other problem it could be. Its doing the same thing it did when the pump went out 6 months ago.
enriched Dec 16, 2011 07:45 PM
only other thought is to make sure your getting proper voltage to the fuel pump connector. Seems like your on the right track
glc Dec 21, 2011 10:25 PM
The internal filter could be clogged. Good chance of that if the inline filter was nasty, you could have some major crap in your gas tank. If you pull the pump, I'd drop the tank and get it flushed.
