Pro's and Con's of having California Emissions in a Different state
Well I am getting ready to buy a new truck, and I was almost set to get it untill he told me it was a California truck. Its a 2007 Chevy Suburban (5.3) Z71.
I don't have the slightest clue on what the emissions controls are on a california.
I also don't know if it will vary much from chevy to ford.
I really would like to get it, but presently I am scared to.
Can someone please tell me the Pro's and Con's of the California emissions.
Do you think that I will have more or less HP?
Does it make a differance in the MPG's of the truck?
Thank you for your help in resolving my problem!!
There are times when they will need to know that it is a Cal. car when you buy parts. Some of the sensors may be faintly different, but I think most of the time even if you tested them, you'd be hard pressed to find a difference... only the parts book knows for sure- I certainly wouldn't be afraid of it. I'd be more concerned that it is now controlled by Government Motors than I would be about the smog.
If there were, it would have passed all of them with flying colors! Can't imagine how there'd be a problem there.
California may be the first state to enact tougher standards but car manufactures build cars to pass in all states rather then just 1. My kids Dodge passes in San Diego every year that I bought for him here in Utah no problem. California was the first state to require catalytic converters and smog pumps in 75 but the rest of the country was right behind them in 76. They may be stricter about not passing poorly running cars but my experiance has been the cars sold there are pretty much the same as the ones sold everywhere else. Actually if you buy a car that passes the emissions test there you know your getting a car that runs right. I wouldn't even worry about the emissions difference. its small.
Correct. I doubt Ford has made multiple state models for years. It is easier and more cost effective for them to just make them all to the strictest standard.
Calif Vehicles
Just spent a couple of months researching this prior to purchasing a 07 F150 Heavy Half last month in Calif. Everything I got from every place (Including Ford) on the difference between the 49 states emissions and Calif emissions vehicles is the cat on the truck is different between Calif and everywhere else. I asked about things like timing, computer code etc and was told it was the same. Obviously this only applies to Fords and if what I got for responses is accurate then it's true. Chevy's could be different so you'd need to check that one out yourself.
I can't say I've seen any difference between this one and others I've looked at in appearance or drive quality when I checked them out. Mileage seems to be about the same for this vs the other ones I looked at also. If it's a little cleaner in the tailpipe, then that's a plus to me.
Paul
PS there is no air pump on mine that I've seen so far.
Paul
Maine, Vermont, Massachusetts, Rhode Island, Connecticut, New York, New Jersey, Pennsylvania, Maryland, Oregon, Washington, and Arizona (also parts of New Mexico).
I bought my truck in New Hampshire and it meets CA standards. I guess that makes sense since 5 of the 6 New England states follow CA standards.
There are at least 12 other states that adopted CA's standards.
Passing a test doesn't necessairly mean same equipment. Cali trucks are different equipment wise. Look on the window sticker, it list "California Emissions". The funny part is, these Cali vehicles are starting to show up in all the states that border Cali. One state (I forgot which one) I checked on, every truck on the lot was a Cali truck. Others were mixed. This will probably more and more become less of an issue, but today according to the sticker, Ford still builds two trucks.
