Help with Start Issue
Old Nov 12, 2008 | 04:00 PM
bigsur's Avatar
For the 3rd or 4th time (since I've owned my F-150), I tried to start my truck and something is going on. The engine turns, picks up like it's starting, and then dies. It's almost as if there's not enough gas to keep it running. When this happens, it takes a few attempts before the vehicle will start. This has only happened a few times over the past year, but when it does, it doesn't sound healthy. Anybody ever had this problem before? Any help is very much appreciated.
Old Nov 12, 2008 | 04:04 PM
Matts ford's Avatar
motor? mileage?
when was the last time the fuel filter was replaced? and could you tell whether or not the pump was running? is it still under warranty?
Old Nov 12, 2008 | 04:09 PM
bigsur's Avatar
Originally Posted by Matts ford
motor? mileage?
It's a 2006 Lariat, 5.6 liter V8, 22,000 miles. I doubt the filter has never been replaced since it's so new. I think I have a few months left on the factory warranty but also have a 3 year extended warranty to work with. I'm hesitant to take it in since this happens so infrequently and will probably have a hard time replicating the issue.
Old Nov 12, 2008 | 04:53 PM
D's984x4's Avatar
Injectors possibly?
Old Nov 12, 2008 | 06:21 PM
Gotts2BMe's Avatar
It's you post this, tonight I was gonna post my situation which is very similar. The first start in the morning, only the morning my truck likes to fire and die right away, then it fires right up. I haven't replaced the fuel filter since last summer I've been meaning to do it. Sometimes it'll catch and start but it likes to fart around, otherwise it runs and drives like normal.
Old Nov 12, 2008 | 06:27 PM
Matts ford's Avatar
try priming the fuel system each morning. see if that helps.
Old Nov 12, 2008 | 07:16 PM
yetti96's Avatar
I would assume you mean 5.4L...but I would take it to the dealer and make them hear/feel the issue. That is the only way to get a stealership to work on stuff.
Old Nov 12, 2008 | 09:36 PM
RacingJake's Avatar
I'd put a fuel pressure gage on the fuel rail and try to start the truck and see what the pressure is during starting. May be a fuel issue ??
Old Nov 12, 2008 | 10:22 PM
tigerballz88's Avatar
I had a similar symptom on my 2006 5.4L 3V just recently but the difference was it would happen at the gas station after I fill up with gas. It would start up but than sputter and stall. Took a few tries to start up again and was fine until I had to fill her up again (about a week later). Spoke with a few ford guys and narrowed it down to the evap system (part of the fuel system). The ford dealership had diagnostic tool that determined it was a evap valve that was stuck in the open position. After replacing it, it hasn't had the problem again. Hope that helps. If it is that, it cost just under $200 to repair.
Old Nov 13, 2008 | 07:28 AM
bigsur's Avatar
Thanks for the replies. I have a call in to the dealer. I'll follow up with a post stating the problem.
Old Nov 13, 2008 | 08:38 AM
JMC's Avatar
JMC
25 Year Member
I would clean the IAC and the MAF to start with.
Regards
Jean Marc Chartier
Old Nov 13, 2008 | 09:39 PM
wreedKR's Avatar
Is this the black valve mounted on the drivers side on the firewall?
Old Nov 13, 2008 | 11:45 PM
Not sure. I'll have to look into that.
