PI head swap
How hard is it to do a PI head swap on a 97 F150 5.4. I found the heads, intake timing cover valve covers, head bolts. Is there anything else i need to do the swap, are the plugs or injectors or anything else different?
same injectors, you need a tune for it.
This thread is talking about the 4.6 but the info is about the same:
https://www.f150online.com/forums/sh...ight=head+swap |
Originally Posted by built54
(Post 3297659)
All I ever keep seeing in these posts from people wondering about working the 4.6's ends up being "go with a 5.4." Has ANYBODY done a 4.6? I read the thread about the PI/Non-PI head swap, and learned little to nothing. Will all the accessory brackets interchange? how about headers--with the non-pi being round and the pi being square? With the PI heads producing higher compression, what about just swapping in a newer 4.6 motor already setup with the PI, like one from a 2001 on up?
Would a person be able to use the newer motor and just transfer the throttle body, timing, oil pan, injectors, etc from their older motor onto the newer one with a tune? Would that work? More to the point, would that work easily? |
Originally Posted by HillsOttfam
(Post 3297838)
'Working on" is a broad catagory, you need to be more specific.
(Post 3297838)
(Post 3297838)
Will all the accessory brackets interchange??
(Post 3297838)
how about headers--with the non-pi being round and the pi being square? ??
(Post 3297838)
With the PI heads producing higher compression, what about just swapping in a newer 4.6 motor already setup with the PI, like one from a 2001 on up? ??
I'm prolly off here, but not by much. The dfference between a 'Factory" PI 4six vrs NonPi = around 11 hp. A head swap -Pi on NonPI Block = 30- 60 hp when combined and tuned - Has to be tuned on the Dyno Period - Or I should say , that's what you'll want to do or everthing thus far will be wasted.
(Post 3297838)
Would that work? More to the point, would that work easily? Just use the search bar. Also , start your own thread - Stealing others isn't to cool. |
