battery level fine, engine wont turn, clicks
i thought my alarm battery died, but engine wont turn. however the battery indicator is norm. engine just clicks with a few seconds inbetween while key is turned...all needles go flat, but when key is stationary all neddles go back to norm. i jumped it and it runs fine., but wont statr after stopping.
starter? |
Are you testing it with the battery indicator on the dash? The battery may be fine without load but it's a while different story once load is placed on it. Get the battery tested, I'm pretty sure it's the battery
Another confirming though I just had, you were able to jump it... That rules out the starter:smoke:
thanks for the tip... i will test asap.
I've had dirty terminals give the same indication. just something else for you to look at before droppin some cash for a new battery.:thumbsup:
Odds are it's a bad battery cable at the starter end. Unless it's been replace in the last 5 years, that's where I'd put my money.
-Joe |
-Joe He mentioned it jumped off fine. Seems like a bad cable on the starter end wouldn't allow it to be jumped off. |
Check the MEGA 175 amp fuse. Theres also a fuse tucked behind that in the cradle. That's mini 30 I think? - Well it's in-line and hard to see at times, just follow the Alternator Harness . It's best to go thru everything. You really can't rule anything out because it will take a jump. I good surge can bridge a bad connection.
If the mini 30 is gone, you'll usually get a battery light tho and it won't charge - Your battery light could be smoked as well??. A MAXI 175 can break instead of blow on either side of the solder ball. That's all they are Copper w/solder joint. The most common problem is that little wire on the starter, but if your battery's over 5 years old , well.......Yea. |
