Running hot, don't know why
Old Jul 30, 2007 | 07:48 PM
jparker's Avatar
My 96 f150 5.0 with 200,00 miles has been running hot, with the indicator 3/4 across the normal ban after a few miles but I have no boil over but I am using water. I have replaced the rad. cap, flushed it, replaced the tstat, but don't know why still hot. Even worse when towing boat. I think that maybe my catalytic converter is clogged or pump is not pumping. Oil is normal. Any ideas?
Old Jul 30, 2007 | 07:50 PM
Turd Furguson's Avatar
Did you ever think that your water pump may be starting to go out?
Did you do a reverse flush?
Old Jul 30, 2007 | 08:00 PM
1/2Breed's Avatar
Might want to take a look at the fan clutch.
Old Jul 30, 2007 | 08:07 PM
jparker's Avatar
I ran it with the cap off and when I increased rpm I could see the water level drop indicating good flow.
Old Jul 30, 2007 | 08:18 PM
Did it ever get back up to pressure where it started to come back out and starting spilling onto the ground?
Old Jul 30, 2007 | 08:45 PM
jparker's Avatar
I didn't let it run that long. When I let off the gas it just came back to the top of the cap area, maybe a little spilled out. What should I look for?
Old Jul 30, 2007 | 09:51 PM
Bluegrass's Avatar
Have the radiator flow tested.
Bet the lower part is plugged, reducing the cooling capacity.
