stutter
Old Apr 30, 2007 | 02:32 PM
gebopper's Avatar
jbrew, my plugs do say "MOTORCRAFT", but just out of curiosity are you telling me that MOTORCRAFT is the only plug that will work on my truck and there is no other brand out there that would work? do you work for FORD ????? lol. just kidding. sorry guys if i seem short, just very frustrated. thanx for all the advice i am getting. i am just going to replace the plugs and wires and then i will get back to you if this is not the problem.
Old Apr 30, 2007 | 03:07 PM
JMC's Avatar
JMC
25 Year Member
You missed the whole point. Even OEM parts can be defective. That is not the rule but the exception. Some tool could have taken one of the plug wires and stretched it and snapped the wire inside it. There could be a tear in the plug wire what will not show up but under close examination. Testing it is the only way to know for sure. Replacing a good wire is a waste of money. Who is to say that the same tool didn't stretch a whole batch of them? Double check your work to be sure you didn't miss something. After testing the wires be sure that they are seated properly. Did you knock something while doing the tune up? Once your work/replacement parts is/are eliminated as the possible cause you can look for other things.
JMC
Old Apr 30, 2007 | 03:47 PM
jbrew's Avatar
No , don't work for Ford at the moment , but have. I had a problem running Bosch plugs at one time . I wanted to be clear about the plugs your using.
You didn't answere my question in my last post
Old Apr 30, 2007 | 04:11 PM
gebopper's Avatar
i did answer both questions. 1 they say motorcraft on the plug 2 it is a man 5 speed. it does not happen when i shift to overdrive. it happens in 1,2,3,4 or 5 depending on wether i accelerate aggressively. it does not happen in any gear if i accelerate slowly.
Old Apr 30, 2007 | 05:13 PM
jbrew's Avatar
I would try cleaning the MAF sensor . Pull the TB and clean it - elbow as well , the ports can get clogged going into the EGR.
Did you post in the V6 section ?
Old Apr 30, 2007 | 06:05 PM
gebopper's Avatar
i have posted on the v6 page, no hits yet
Old May 1, 2007 | 08:11 PM
Dan_J's Avatar
I have posted in that forum before also. I rarely got a response to I tend to come back in here where the folks are a lot more helpful.
Old May 1, 2007 | 08:33 PM
jbrew's Avatar
LOL - Good excuse , I know whatcha mean - welcome ..
Old May 1, 2007 | 08:48 PM
Dave68iou1's Avatar
If the O2 sensor were bad, it would most likely cause the Check Engine Light (CEL) to come on. It's a quick fix. Have you noticed any abnormal temp ranges while the stutter happens? I had an issue with the water pump that started this way. The gap may be an issue (especially if you knocked the tip of it while trying to get it in). If none of these apply, then I would have to agree with the others to have your ECM checked for error codes and faulty ignition points. Hope this helps
